Brief Description: Fixing Doors ready for covering
During my installation of the central cam lock from Planearound, I made a cut into the door section to accomodate the travel of the pin rod. This was due to the fact that I decided to have a rivet stop for each of the rods, not just one.
The byproduct of this change in design, was that the hole needed to be covered up.
Also, I have noticed on most sites that the attachments for the door hinges are also covered up, so as part of my "finish door ready for upholstery, I did them also.
The tool that I have made allowing for the step bolts to be inserted later, will also allow me the ability to tighten the hinge bolts.
