The RV-10 Dream
Date:  9-9-2014
Number of Hours:  3.00
Brief Description:  G3i Mag modification
Tonight I modified the Magnetos to include the coil stud assemply required by the G3i Ignition System.
Apart from this being the first time I have disassembled a Magneto, it went quite quickly. Mind you, I did do about 5 hours study last night in preparation for this event..... :-0
The process went very smoothly. I have assembled them, however, will reassemble tomorrow night with locktite, proper torquing of the screws and epoxy (for the Coil Stud Assembly).
Once completed I can finalise the ignition harnesses.They require the plug terminals crimped onto the ignition wire and the springs final mounted to the Mag cap.
Thems was Mags.....!!!!
Modification: Coil Stud
Studs on  :-)
Studs on :-)
