The RV-10 Dream
RV-10
s80 Engine
4-6-2013
Mounting Engine
Well it took only a small amount of time in reality to actually bolt the engine to the fuselage, however the panic in doing so was enormous.
Bolted right up seamlessly. Lovely. Jamie helped quite a bit with the final manouvering. Bolts went in quite well.
Opening the Engine
Isn't she beautiful
Bolting it on.
RV-10 Home
2194
AA Tips/Technique
s01 Garden/Garage
s02 Workshop Fitout
s03 QB Kit
s06 Empennage
s06 Vert Stabiliser
s07 Rudder
s08 Horizontal Stab
s09 Elevators
s10 Tail Cone
s18 Fuel Tank
s19 Stall Warning
s20 Wings
s23 Aileron Actuator
s24 Wing Tip
s29 Fuse Side Skins
s32 Tailcone Attach
s33 Baggage Area
s34 Baggage Door
s35 Floor panels
s36 Brake lines
s37 Fuel System
s38 Pedals and Brake
s39 Control System
s40 Flap System
s41 Up Fwd Fuse Inst
s43 Cabin Cover
s44 Wing Attachment
s45 Cabin Doors
s46 Eng Mnt and Lndg
s47 Spinner & Cowl
s48 Gear Legs
s49 Seats and Belts
s50 Cabin Heat
s80 Engine
25
158
s85 Prop
s90 Avionics
45
229
s99 Miscellaneous
sFF1 Engine Install
sFF2 Cowl Baffle
sFF3 Control Cables
sFF4 Fuel System
sFF6 Exhaust System
sPNT Painting
sUP Upholstery
Test Flights
z0 Maintenance
