The RV-10 Dream
Date:  8-27-2013
Brief Description:  Setting GTN650 and PAR100EX
I have tonight refit the panel to check the fitting of the Rudder trim and to begin the fitting of the cages for the GTN650 and the PAR100EX.
I am pretty happy with the fitting of the trim and the cages will fit in very nicely. The cages need to be drilled and I ned hardware for the cages to the mounting brackets, however, the rear ones are designed to move and the front ones are in an excellent position.
The layout is excellent and Iam very hapopy with the switch and instrument locations.
Full Panel
Full Panel
Little closer
Little closer
