The RV-10 Dream
Date:  11-3-2013
Number of Hours:  5.00
Brief Description:  Control sticks
Dad and i focused on setting the control column up with the Infinity grips.
The setup I chose added a little weight, however looks excellent and shouldbe quite hardy. I used a form of shrink wrap tape. Basically it has a glue on it and once wrapped and heated both shrinks and glues itself to the object being wrapped.
This has worked out very tidy in containing the grips wiring back to under the seat. This should be wired up soon to a control connection panel.
Attached and wrapped
Clearence good
Clearence good
