The RV-10 Dream
Date:  11-19-2011
Number of Hours:  10.00
Manual Reference:  39-3.6
Brief Description:  Control Column Fitment
Now I am on to the control column and associated systems. Over the course of the Saturday and Sunday, I test fit, drilled, primed and completed the components of the control system.
With loose conections I have now test fit the components associated with the control rods.
There was an issue however with the drilling of the control columns and they turned out badly. I need to get them welded shut and then I will redo them.
Central Bell Crank
Central Bell Crank
Main push rod
Main push rod
First mock-up of control columns
