The RV-10 Dream
Date:  1-16-2011
Number of Hours:  5.00
Manual Reference:  6-3 VS
Brief Description:  Match drilling and dimpling
I have assembled drilled, unassembled deburred, assembled, drilled, unassembled, deburred, covered the dimpling table with carpet, dimpled AND.........whalla!!!!
I have a completly dimpled VS skin and all of the ribs ready for the final assembly. I still need to countersink and debur the VS rear spar, however, apart from that, the VS is virtually ready for priming.
I am awaiting some info from the VansAirforce Forum as the countersinking is on a thin piece of metal and I need to understanding the process.
As to the dimpling, the DRDT-2 dimpler is AMAZING!!!!
It is very easy to use and the dimples are coming out beautifully and conssitently. It is really easy... what can I say. Its good, I recommend it whole-heartedly.
Now if I can just understand what the paint is that I need to get.....mmmmm.
Currently I am investigating a very good prospect that uses PreKote and then a 2-pack epoxy primer. Both non-chromium and according to US Military and non-military testing, performs as well as its Chromium based counterparts.
I will keep you all informed of the paint progress as I am sure all out there are interested. :-)
Dimpling the VS Skin
Look at that line  :-)
VS skin dimpled..
VS skin dimpled..
