Fabricated the two doublers for the L/R elevators. These will go inside of the root rib as mentioned in the last log entry.
Right elevator - Cleco'd and drilled the elevator horn to the spar and root rib. Disassembled the elevator; deburred skeleton, cleaned edges, countersunk and dimpled spar, dimpled root rib, beveled the counterbalance skin.
