HS - Installed the rear spar in the Horizontal Stabilizer and finished riveting assembly together. All that is lacking is: Install two AN426AD-3-3.5 on the right end of the right HS. Need to torque the bolts that hold the center hinge/bearing assembly. Neet to trim the rear spar below the center hinge/bearing assembly.
