Completed the following steps on the L & R rear spars:
* Trim the ends and deburr the edges of W-707G & D as shown on DWG 10A & DWG 38.
Begin rear spar assembly by clamping the W-707E and W-707F doubler plates to the spar. Vertical placement is correct when the flanges of the spar and the reinforcement plates are tight. Lateral placement for W-707F is determined by aligning the outboard edges of W-707F and the W-707A spar channel. To place W-707E measure the distance between the outboard edges of W-707E and W-707A (See DWG 10A).
* Using the spar as a template, clamp, drill and cleco W-707E/F to the W-707A spar channel.
