Tony’s RV-7
Date:  9-5-2020
Number of Hours:  2.82
Manual Reference:  Section 7
Brief Description:  Main Spar - Countersinking Access Panel Plate Nuts
L & R Main Spars
Completed:
* Attach the K1000-06 platenuts for the W-822 access plate to the W-706A flange (note that the access plate uses #6 screws on the spar flange and #8 screws around the perimeter.) See DWG 12. Dimple the access plate for a #6 screw, then machine countersink the spar flange to fit the dimples. Use a #40 piloted countersink cutter to center in the platenut.
* Attach the two K1000-4 center section attach nutplates to the forward side of the spar. Countersink the W-706C doubler plate to allow the flush heads of the rivets to rest on the aft side of spar.
* Spot prime all countersunk holes where the anodizing has been removed.
Started gathering material and reviewing drawings for the tie downs.
