Brief Description: Left Elevator & Trim Tab Assembly
Completed the following task on the left elevator and trim tab: * Set the blind rivets in the ends of the trim tab, making sure they don't interfere with the rivets in the inboard tabs of the elevator. * Roll and rivet the leading edges. Had to install extra rivets in one section of the leading edge to get it to lay down smoothly. * Install the rod end bearings. The drawings call for 13/16 to 7/8" maximum. I set them at ~27/32".
