Brief Description: HS - Riveting Right Horizonatal Stabalizer
Riveting the right side horizontal stabilizer together; Started to install the rear spar on the horizontal stabilizer assembly and realized that the rear spar was not assembled correctly. Drilled out all rivets on HS-603PP and HS-609PP and re-assembled the rear spar correctly.
