Tony’s RV-7
Date:  11-8-2019
Number of Hours:  7.45
Manual Reference:  Section 6
Brief Description:  HS - Right HS Assembly
Right side HS
Cleco'd right side skin (HS-601PP) to HS skeleton; enlarged the HS-708 to HS-603PP holes to #21;
Set up and match drilled HS-00005 to HS-603PP, removed, cleaned and deburred; Match drilled HS-00006 to HS-702 and HS-00001; Marked and drilled two holes common to HS-00001, HS-702, HS-710 or HS-714 on the forward side of spar bars; Set up and match drilled holes in forward flange of HS-00005 rib; Match drilled HS-601PP (skin) to HS-00005 and HS-00006; Match drilled and drilled to final size all remaining holes attaching HS-601PP (skin); Removed skin and drilled remaining holes in HS-714, HS-710 and HS-00001.
Left and Right HS skeleton assembly
Started deburring, edge cleaning, scotch brite (scuffing) and marking HS skeleton parts.
