ARTHUR'S WEB SITE
CH701
Controls Sect 2
I made blocks to get the plane up enough to slide under the belly to the access hole. Tight fit. Cut the "L" angles at 320 mm and 460 mm and then drilled the 3/4" holes in the bearing plates 7F6-3.
Instll the 4 "L" angles. what a job that was.
Blocked up
Bearing plates
CH701 Home
667
Cabin
Elevator
Gear
Horizontal Stabilize
Panel
Tail
