This morning I fabbed the aileron trim slider bar. Then I made the spacer blocks for the center spar section. I had some spare 2X12 laying around so I cut it to size and planed each to the correct thickness.Then I finished the center spar assembly. It was nice to get a major part of the fuse done. I also trimmed the caps that go over the center section bulkheads and bent the side pieces.
