Spent a lot of time trying to figure out where the holes for the electrical conduit should go. I ended up building a jig so all the holes will end up in the exact same place. It worked really well. I drilled pilot holes in all the left wing main ribs. I also got the rib to spar holes drilled to size, then disassembled the skeleton.
