Adam's CH750 Cruzer
Date:  2-9-2019
Brief Description:  Mounting wheels and tires on spring
Got the tires, wheels, brakes, etc.. all mounted onto the main gear spring today. Took a little bit of effort with some tire talc, lubricant, and bending of the valve stems to the wheels assembled, but it went smoothly. Getting the axles mounted on the spring was a little more work. This involved filing down a corner of the bottom of the spring to create clearance for the brake calipers.
