Brief Description: Finished drilling mounting holes for horizontal st
Drilled the holes for the horizontal stabilizer to final size finally. After a lot of work lining up the angle of the stabilizer and the stress of starting the holes before, this was much sless stressful. After the holes were drilled, bolts were inserted to check fit. The angle of the stabilizer was a tiny bit off at this point, but still well within the limits that Zenith indicated would be acceptable.
