Mounted the nose gear fork on. This involved marking out all 6 holes in the strut and the the fork and drilling them out together with the fork clamped on the strut. One of them ended up a little too close to the center of the strut so I needed to grind out a tiny bit of the weld to make the bolt fit. Once that was installed, I put the strut on the plane and bolted in the bearing and safety wired the 4 bolts.
