Brief Description: Elevator assembly, hinge fitting.
Finished assembling the elevator and control horn/counterweight arm, trim tab, etc.. Then the elevator was fitted up against the horizontal stabilizer and the hinge was fitted and drilled out. We noticed that the elevator did catch on the stabilizer tip caps and will need to be filed down upon final assembly. I also tried to get the main wheels assembled but noticed that the tubes were not centered on the rim by the rim design, so I set that aside to figure out after contacting zenith.
