Continued with the flaperons today. Got all of the parts finally drilled out as needed, and cut the outboard brackets to fit. Then the ribs were painted for corrosion and riveted onto the spars along with the L-angles for the tip ribs. The entire skeleton was then painted for corrosion protection and clecoed into the skins. Once the skins were fitted on the skeletons the top half of the skins were riveted onto the skeleton.
