Brief Description: Flaperon arms and wingtip L-angles
Dan took on some work on the right wing today. Two primary things were completed. The flaperon arms were paired with their respective ribs and the L-angle supports were cut to match and then the holes were all drilled out to final #20. The other part of the work was to make, drill, and rivet the L-angle on the tip of the spar for the plastic wingtip to go on later. The rear spar L-angle was also cut and set aside for once the rear spar is installed.
