Adam's CH750 Cruzer
Date:  8-12-2018
Number of Hours:  4.50
Brief Description:  Fuel tank fitting and running hoses
Now that all of the fuel tank setup is done I was able to put it in the wing and drill and cleco the bracket onto the back of the bay to support the tank, and then start to put the cork strips on. Aslo drilled out the rear spar with a hole saw for a grommit to put the fuel return line through. There was a bunch of trial and error with the corking to get the tank set and the skin supported to make a good fit of the fuel cap bevel onto the top skin. Lastly I riveted the fuel sender grounding wire from the tank to the wing rib.
