Brief Description: Strobe light wiring and cutting fuel sender hole
Two things today. Started by stripping the strobe light wires to prep for when the wing tip gets installed. Carefully had to strip the shielding so that it could be twisted and grounded to the airframe. Once stripped, it was connected to a jumper wire and riveted to a rib with a ring connector. Stripped and left with a jumper wire at the wing root as well. Second thing was to start on the fuel sender. I followed the instructions from the STOL photo guides and bent the float rod to 125 degrees. Second, I cut out the hole in the tank for the sender. Again, I followed the guide from the STOL fuel system instructions. Used a fly cutter to cut it out and it ended up working quite well.
