Brief Description: Flaperon arms, landing light assembly, R wing skel
Deburred the flaperon arms for the left wing, clecoed in place and drilled the 4 A4 holes for the flaperon arm L angle. L-angles deburred, joining surfaces painted for corrosion protection and then clecoed back in place and all four flaperon arms were riveted onto the ribs. Meanwhile, Dan assembled the landing lights into the housings and backing plate and then started on the right wing. The ribs were celcoed onto the spar and drilled to size. Started to deburr the ribs, reassemble onto the spar. The nut plates for the inspection ports were also drilled and riveted into place.
