Today I started working on the skin for the left wing. Clecoed the skin onto the skeleton to check fit and then measured the length between the ribs and flanges in each bay of the wing for the L-angle stiffeners. Once they were all measured, L-angles were cut (two of each, one top and one bottom) to fit the appropriate bays. Once all of them were cut, they were placed in their appropriate bays on the bottom skin to start drilling them. Once the first couple holes were drilled, they were clecoed in place and the holes were all drilled out and expanded to for A4 rivets. After all the stiffeners were drilled and expanded, the wing was flipped back over and the holes for the rear skin were drilled out and expanded with the exception of the rivet line along the spar. This will be done later when all skins are together.
