Richard's Web Site
Date:  2-14-2016
Number of Hours:  5.00
Brief Description:  Attach oil cooler and hoses
Attaching the hose is a challenge. I later discovered that the best way is to put the hose fitting into a protected bench vise, heat the tubing and put your entire weight into it. Good exercise. The hose positiions will probably be changed when the engines are actually mounted so these views of the hoses may not be their final positions.
Oil cooler and a few hoses
Oil coller with a few hoses
Oil cooler hoses
Oil cooler hoses
