Brief Description: Placement of horizontal front spar eyebolt coupler
This step 8-30 should be considered when you complete work at 8-11. In my kit VS-021 would not fit through the opening in VS-016. See pic 2. In order to accomplish the task I put VS-016 into my drill and spun it while using scotch brite to reduce its diameter. I then used some oil on the part and spun it into VS-021 using my drill bit. See pic 3.
