Richard's Web Site
AirCam
Elevator
4-9-2015
Attaching Nut Plate Bracket
#1. I used a punch to mark the drill locations on the first rib EL-005 onto which the outboard end of Nut plate El-007 would be attached. The 3 holes were easy to drill once the nut plate was removed.
#2 Right EL constructed in same manner as L
Marked Rib El-002 for riveting
Right EL
R side completed
AirCam Home
720
Ailerons
Attaching and Riging
Brakes
Center Section
Elevator
Fabric
Flaps
General Remarks
Horizontal Stabilize
Instruments
Move to HND
Rigging
Throttle controlls
Throttle controls
Vertical Stabilizer
Wiring
