Kelly continues his work on the electrical wiring while I run cables for radio and transponder. If you think about where you want the radio and transponder antennae before this stage you may consider cutting holes in the FU and adding a doubler plate. The A & P will suggest that you need at least 3 feet between these two antennae.
Pics 2 & 3. I did not like the sharp and unfinished edges at the rear of the baggage compartment so I added covered them with rubber edging material.
