Brief Description: Pulled the spark plugs to record wear.
Pulled the spark plugs to record the wear that was inflicted during the factory run up and testing period. We now have a baseline for comparison later.
Part of our initial engine inspections was to check for leaks of oil, water and coolant. A small coolant leak was discovered and repaired by tightening the clamps around the appropriate hoses.
