Brief Description: Install elevator horn and counterweight
Placement of elevator push rod. Adjusting the push rod to 43 5/8 inches is not an issue but I used lots of Locktight on LLC-40 and its jam nuts. I have heard of one instance where these parts separated resulting in an incident. At time of final assembly and rigging I will see if there is a good way to permanently ensure that this wont happen here. After assembly here I marked both CS-034 and MS27975 so that I could determine movement during condition inspections. Cleco leading edge skins to frame. pic 2
