Richard's Web Site
AirCam
10-20 and 10-21
Flap motor channel and angle
Pic 3. Used Dremmel to notch the bottom rear spars. Plans call for notch about 1/8 deep and 1/2 inch wide. When I later mated the CT to the FU the two rear struts CT0006 the notch size is slightly larger than required however it is not visible.
Angle
Channel
Notch rear spar
AirCam Home
720
Ailerons
Attaching and Riging
Brakes
Center Section
Elevator
Fabric
Flaps
General Remarks
Horizontal Stabilize
Instruments
Move to HND
Rigging
Throttle controlls
Throttle controls
Vertical Stabilizer
Wiring
