Als Sonex
Sonex
Specifications
9-8-2007
Engine Specifications
Continuous HP, 3400 RPM 80
Bore (mm) 92
Stroke (mm) 82
Displacement (cc) 2180
Compression Ratio 8.0:1
Oil Capacity 2 3/4 US Qts.
Oil Type SAE Multigrade 20/50
Firing Order 1-4-3-2
Spark Plugs Autolite MP4163 or equivalent
Carburetor Aero-Carb ACV-C03S
Starter Geared
Alternator Output 20 Amp
Weight (less oil and exhaust) 158 lbs
Propeller Drive 1.1
Prop Bolt Pattern Qty 6, 5/16" diameter @ 4" Center
Prop Drive Bushings 9/16" diameter X 7/16" Long
Battery Required 12v @ 20 amp
Idle RPM 700-900
Cruise RPM 3200 +/- 200
Maximum RPM 4000
Oil Temp. Min. 160 degrees F
Oil Temp. Max. 230 degrees F
Oil Pressure Min. 20 psi
Oil Pressure Max. 100 psi
Oil Pressure @ Cruise 40-50 psi
CHT @ Cruise 350-375 degrees F
CHT @ Climb (5 min) 420 degrees F
CHT Max 450 degrees F
EGT Max 1400 degrees F
Sonex Home
Documentation
Specifications
