Als Sonex
Sonex
Aircraft Specifications
Specifications:
Length 18' 1"
Wing Span 22'
Wing Area 98.0 sq. ft.
Tail Configuration Conventional
Tail Width--with tail tips 92" (interior width required for enclosed trailer)
Air Foil 64-415
Primary Structure 6061 aluminum
Cockpit Width 40 in.
Fuel Capacity 16 US Gal.
Stall Speed (full flaps) 40 mph [64 km/h]
Stall Speed (clean) 46 mph [74 km/h]
Max Flap Extended Speed (Vfe) 100 mph [161 km/h]
Maneuvering Speed 125 mph [201 km/h]
Never Exceed Speed (Vne) 197 mph [317 km/h]
Performance:
Empty Weight (average) 620 lbs.
Range 550 miles
Cruise Speed @ Sea Level* 130 mph
Cruise Speed @ 8000 ft (TAS) 150 mph
Power Loading (GW/HP) 13.125
T.O. Distance 400 ft
Landing Distance 500 ft
Utility Category:
Gross Weight 1100 lbs
Baggage (Max) 40 lbs
Useful Load 480 lbs
Rate of Climb 800-1000 fpm
Positive Load Factor +4.4 Gs
Negative Load Factor -2.2 Gs
L/D 11:1
CG Limits 20-32% Wing Chord
Aerobatic Category:
Gross Weight - Aerobatic 950 lbs
Baggage (Max) 10 lbs
Rate of Climb 1000-1250 fpm
Positive Load Factor +6.0 Gs
Negative Load Factor -3.0 Gs
CG Limits 25-29% Wing Chord
Sonex Home
Documentation
Specifications
