Brief Description: Installed Stick to idler elevator pushrod
installed the front elevator pushrod assembly. This goes between the sticks and the elevator idler just behind the baggage area. Plans call for zero degrees vertical, zero degrees side to side on the stick and the idler should be vertical. You can tell from the last picture that's its just a little aft. Some people say that it needs to be 10 degrees aft. I think I'll end up waiting until the elevators are in to determine final postion.
