Original bracket has to be taken apart and the lower nutplate had to be removed and the bolt moved up. Then the bracket had to be trimmed to clear the fuel pump and the fitting that will exit the fuel pump and go to the gas colator. The opposite side of the fuel pump bracket had to be cut to allow clearance for the overflow fitting. Then the mount side of the bracket had to be narrowed to allow it to fit inside the center console.
