Brief Description: Installed the fuel selector mount
Cleaned, preped, sanded, and floxed in the fuel selector mount on the centerline and in front of the fowards spar. Prior to gluing in, I also drilled the two back holes for the Marker Beacon antenna that will be mounted from the inside out via bolts
