Lancair Legacy FG-6
Date:  9-20-2005
Number of Hours:  4.00
Manual Reference:  Chapter 9
Brief Description:  Canopy Hinge part 4
Floxed in the fuselage hinge points. used an interesting trick as well. If you take a qtip and a blue marker and soak the tip of the qtip with ink. You can use it to transfer the bolt hole drill point to the forward fuselage mounts prior to bonding them in. Worked great. We are also going to make one modification. These are hard points in the underside of the fuselage and so we'll drill and countersink a set of screws on both of these brackets to make sure they never come loose. They also get a 3 BID Layup on each.
