The bellcranks is installed in a bulkhead that is apart of the fuselage. There are three bolts that secure it to that bulkhead. Nut plates are pre-installed by the factory and I used drilled bolts for the center and front bolt. I then safety wired these two bolts to maintain security of the belcrank. The rudder cables are installed in existing tubing that is embedded in the sides of the fuselage. The center cables will be installed in feedthrus that will be installed in the autopilot bulkhead, the baggage bulkhead and the seat backs. These cables run thru plastic tubing to provide a bearing.
