Lancair Legacy FG-6
Legacy FG
Chapter 9
Canopy hinge part 2
Using shims under the canopy hinge, you first drill the main bolt holes and pattern. Then you add blind nuts and rivets and you work to make sure that they are level so they pull the hinge frame into their mounts smooth, straight and correct
Legacy FG Home
301
Ailerons
Antennas
AutoPilot
Center console
Firewall
Flaps
Flight controls
Fuel system
General cockpit
Instrument Panel
Landing gear
Seat bottoms
