Removed center spar section for mods. Had to remove both rear spatr supports to get center section out. I left all the dual control pieces together with out removing otherwise probably could have taken the spar out without removing the supports. All wiring static lines etc go over the spar so that made it much easier, only the rudder cables go through the spar web.
