Got the front edge of the canopy fitted with the seal in place. The rear edge is marked out for fitting with the seal on it. It fits tight without the seal so some will have to come off all the way around. The front is snug all the way around except at the canopy rail area.. If I shim up the top cowl piece in that area I probably would not need the metal trim piece. I am using a #8 3/4 inch screw to hold the cowl in place so shimming would not be a problem. The gap is tp much to let go, rain would be a problem so would cold weather. Still waiting for my engine, it is holding me up now, everything else is ready to go to thre airport to put on the wings.
