Mounted oil bracket on firewall with oil temp and oil Pres. senders on. Still have to wire. Trimmed canopy down to sit on bows. Fits good. Used a cut off wheel in the Dremel tool. Had to make two cuts off back end of canopy that's all.
Fit is well within 1/4 inch all the way around
Fuel primer and fuel pressure mountes
Oil filter bkt with temp and pressure senders mounted.
