Continued on intercom wiring. Just have the two PTT switches to wire, the pilots just needs a hook up. Then a checkout for correct pin positions and then support through the arm rest. I will be glad when it's done. Quite intensive work. Instruments have to be wired and the battery. I have to get in touch with WW to see what he is using on the engine and what I have to provide. I don't know where I will put the battery, but right now I figure behind the passenger seat, I don't care for the long run t6o the battery relay located on the firewall but!!!
