Continued teardown of engine. Other head (Left) necessary to chisel nuts on two nuts and used nut buster on two others. All nuts off but head won't budge. Soaking. Distributer out and front housing loose but hung up on something, moved out enough to get dist gears disengaged, cam does not turn, dist shaft wouldn't turn ( now freed up). I asked Ward if he could get another engine, one that turns over. This is too much work. I will continue to take apart to salvage what I can. Engine block number T1102RA Head number 3856743
