Started installing the cabin heat system. Control on L.H. side of center panel. I have to decide where to install the valve on the fire wall. Don;t really want it blowing on fuel or oil. Ordered throttle and mixture controls and will put them on bottom center of the panel. Hve carb heat to go. Installed the heat valve on right side of firewall. If needed I can put a deflector plate over the gasolater. Put the control on the right side of the VHF.
