Still working on fwd top cowl. It will be five pieces instead of one. A removal piece on the left and one on the right. Three pieces will be riveted on. This will allow getting in back of the instrument panel from the outside. A top center panel will be riveted on and the bottom fwd side panels will be riveted. A lot of work but will be much better than a solid riveted panel. No way can you get in back of the panel from the inside.
