ALBERT'S WEB SITE
Date:  10-30-2006
Manual Reference:  6B8
Brief Description:  Engine mount bkts
Worked the lower enginr mount brackets.
Just have to finish drilling and installing another bolt on each side.
Used a piece of the fuel tubing to act as a drill guide for the bolts.
Had to cut down the O.D. just a bit.
Then inserted drill tubing into mount and firewll and used that as a guide.
Line up was good so it worked well.
Top bolts heads fwd
Top bolts heads fwd
Bottom bolts heads aft
Tube as drill guide
Tube as drill guide
